I have an axoloti with lots of pots but only two buttons, and wondering what the best method would be for setting up multiple stomps/effects that I could latch on and off with pots, maybe some type of volume or parameter control? I am also confused how to use the soldered buttons to latch something permanently on/off, they seem to trigger as long as I hold it using the button object. Thanks for any feedback, if anyone has any guitar patches to share please do!
Guitar Effects Chain
janvantomme
Some quick ideas, haven't tested them since I don't have an axoloti with extra hardware on my desk now.
Use the button with a counter to toggle a mux or demux object on/off. Can also be used with a mux 8 for instance to select between 8 signals.
Use a pot to toggle a mux object.
Use a pot to control a mix/xfade object to mix between dry wet, or between different effects.
Thanks I will definitely try these out along with the effects from your book! Super appreciate it!
