Even if it is a purely pressure sensitive keyboard - without velocity nor mechanical parts - I think it is really nice for some sort of sounds (warmpads, brass and solo strings).
With the FSR72, the problem is that stacked octaves cause issues when playing melodies, it is not very natural to go from line to line. Thus, i think having two octaves per row would be nice.
I would say 96 keys on an hexagonal pattern
Different layouts (with redundant keys) are possible:
oct:note
stacked octaves à la Janko (5 octaves):
3:01 3:03 3:05 3:07 3:09 3:11 4:01 4:03 4:05 4:07 4:09 4:11
3:00 3:02 3:04 3:06 3:08 3:10 4:00 4:02 4:04 4:06 4:08 4:10
2:01 2:03 2:05 2:07 2:09 2:11 3:01 3:03 3:05 3:07 3:09 3:11
2:00 2:02 2:04 2:06 2:08 2:10 3:00 3:02 3:04 3:06 3:08 3:10
1:01 1:03 1:05 1:07 1:09 1:11 2:01 2:03 2:05 2:07 2:09 2:11
1:00 1:02 1:04 1:06 1:08 1:10 2:00 2:02 2:04 2:06 2:08 2:10
0:01 0:03 0:05 0:07 0:09 0:11 1:01 1:03 1:05 1:07 1:09 1:11
0:00 0:02 0:04 0:06 0:08 0:10 1:00 1:02 1:04 1:06 1:08 1:10
iso 3m and 3M (harmonic accordion, 3 octaves):
2:01 2:02 2:03 2:04 2:05 2:06 2:07 2:08 2:09 2:10 2:11 3:00
1:09 1:10 1:11 2:00 2:01 2:02 2:03 2:04 2:05 2:06 2:07 2:09
1:06 1:07 1:08 1:09 1:10 1:11 2:00 2:01 2:02 2:03 2:04 2:05
1:02 1:03 1:04 1:05 1:06 1:07 1:08 1:09 1:10 1:11 2:00 2:01
0:11 1:00 1:01 1:02 1:03 1:04 1:05 1:06 1:07 1:08 1:09 1:10
0:07 0:08 0:09 0:10 0:11 1:00 1:01 1:02 1:03 1:04 1:05 1:06
0:04 0:05 0:06 0:07 0:08 0:09 0:10 0:11 1:00 1:01 1:02 1:03
0:00 0:01 0:02 0:03 0:04 0:05 0:06 0:07 0:08 0:09 0:10 0:11
iso 4th and 5th (à la stringed instruments, 5 octaves)
3:07 3:09 3:11 4:01 4:03 4:05 4:07 4:09 4:11 5:01 5:03 5:05
2:07 2:09 2:11 3:01 3:03 3:05 3:07 3:09 3:11 4:01 4:03 4:05
1:07 1:09 1:11 2:01 2:03 2:05 2:07 2:09 2:11 3:01 3:03 3:05
0:07 0:09 0:11 1:01 1:03 1:05 1:07 1:09 1:11 2:01 2:03 2:05
It will be scanned 3000/8=375 times per second. Which should be enough considering the kind of sound I want to control.
My goal is to keep it compact (30x20 cm or so). That's why i stack octaves.
If you prefer a wider format, i think it is quite possible.
I think that a 12 x 16 = 192 key keyboard is still doable (scan freq=3000/16 = 187 times/s using 74HC4067 mux,16 2N7000 and 192 1N4148)... but that's a lot of work.
