Hi @ll,
I have my Axoloti now for some month but had no time to use it - until now! I want to manage a (perhaps) strange setup:
MIDI-USB -> [USB-MIDI-Axoloti -> [???] -> MIDI-OUT-Axoloti]->external_MIDI_Arpeggiator->[MIDI-IN-Axoloti->Axoloti-Patch->...]
In words:
I want to use my small AKAI-MPK25-USB-MIDI keyboard connected to the Axoloti, but want to trigger Axoloti-patches via my external MIDI-Arpeggiator. How can this be arranged? I don't know what object to use for "[???]" in my simple circuit above and how to tell the patch to get the MIDI input from the DIN-MIDI in (instead of USB-MIDI).
I tried a little bit with some objects I found, but couldn't get it to work. Perhaps someone has a working patch or a hint where I can learn from?
Thanks, Holger
! Now I have:
Do you have any idea what is going wrong?
!!! Took everything downstairs to my home-studio: No - nothing happens. After some deeper investigations I found that one of the MIDI cables has a problem -> loose connection, but only sometimes: AAAAAAAAAARGH
