Thought Id share my finished enclosure to hopefully inspire /assist others...
It has the following controls:
8 LED lit Potentiometers
1 Momentary Switch
1 Standard switch
1/4" TRS IN (with Mono/Stereo switch)
1/4" TRS Out
Micro USB
1/8" TRS Headhpones Out
Center negative Power in
Built in a Hammond 1591ESBK ABS Project Box
Not the prettiest thing in the world, but its fully functional and suits my needs quite well.
I may add a few more controls in the future, but for now I'm calling it done.
it is designed to be used with my guitar and Im running a patch that is a tape delay>Auto Pan/Swell>Feedbackloop tape delay pan-final.axp (50.2 KB)
Finished Enclosure pix
Axoloti no longer powers up
Expansion Box for controller
here's my effort:
2x axolotis in series inside a koma field kit box.
the 'front' axo is intended for synths, samplers, sequencers etc and has the lower oled, two big knobs, the joystick, the 5 thin pots and the 5 buttons.
the 'back' axo intended for loopers, effects etc has the upper oled, the four top pots on the right and neighbouring buttons.
in addition I have a teensy 3.6 inside, with another oled strip, as a controller that sends midi to both axolotis and is controlled by the two encoders and the 2x 4x4 button matrices. I intend to create some useful arduino apps for that as the matrix buttons are best used to trigger macros rather than as a playable musical keyboard
I also have a SAM2695 midi GM synth board inside so as I have a simple optional sound pallette to drive with midi.
just finished it yesterday and apart from my crude aluminium cutting skills, it works very nicely.
power comes in through a DC 9v - 12v plug with an on/off switch in the case and distributes to the axos and 5v to the teensy and the sam2695.
I don't think i'll fit anything else inside as it is a birds nest of wires already.
