I'm making a drum machine that uses longer sound files. The uploader skips my RAW-files that are larger than 8MB - why this restriction? The upload is also quite slow, can I just put the files on the SD card directly from my computer?
Filesize restriction when uploading to SD-card
johannes
They're skipped for automatic upload, because upload is quite slow, and you'd probably be faster putting them on sdcard with a cardreader. So far there is no clean way to abort an upload, inadvertently initiating the upload of a large file 'd be annoying.
