Challenger: @philoop
Challenge: Melody/Chord/Rhythm/Bass line generator
Create a patch which includes a generated Melody and/or Chord and/or Rhythm and/or Bass line.
The patch should feature, at least 2 parameters for real time composition control, e.g Density/Pattern/Resolution/Scale and at least 2 parameters for real time controls to alter sounds of the patch radically.
Additional controls for controlling the sounds can also be included.
volume and tempo controls should be included, and are not counted towards the above control requirements.
Place all controlling parameters at the top of the patch for ease of use.
Submission window: Sat 27th 00:00 - Mon 29th Feb 23:59 (CET) OPEN
Voting window: Tue 1st - Sat 5th March 23:59 (CET)
Constraints:
- volume and tempo control at top of patch
- 2 parameters for real time composition control e.g. Density/Pattern/Resolution/Scale
- 2 parameters for real time controls to radically alter sound of patch
- single patch file (axp)
Voting Criteria:
- Usability
- Tweak-ability
There will be two voting polls, one for the overall best patch (3 points) and a second for best sound design (1 point).
Hints/Suggestions:
- use modulation sources
- use presets
- use patch/patcher for polyphony rather than axs (due to single file constraint)
- you can use firmware samples for percussion, but no external samples (due to single file constraint)
... but still look forward to seeing what others have done.
