Faulty Hardware
Hello everyone
I received my axoloty unit as accomplishment of a short course I did.
The unit was `working perfectly during the two weeks of studying, but as soon as I brong that home i never managed to make it work again somehow.
Since it doesn't connect with the computer i originally worked on either i have to think that there something wrong with the interface itself, maybe due to some safeguard errors carrying it away without a case.
Below I left the message i receive from the software in response at my attempts to connect it.
I hope some of you would be able to suggest me what to do with it,
Cheers!
Axoloti version : 1.0.12-2-0-g60a2f99 build time : 08/04/2018 20:20:07 CEST
Link to firmware CRC E95BAC96
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
search path : C:\Users\Giulia\Documents\axoloti\axoloti-factory\objects
search path : C:\Users\Giulia\Documents\axoloti\objects
search path : C:\Users\Giulia\Documents\axoloti\axoloti-contrib\objects
finished loading objects
I have one board that does this too. I never found out exactly what is was, but I think someone told me it might be afried usb port..... And thats why you get the:
I have absolutely NO idea why it happened and how to fix it, sorry..... or if its even possible.
I think @johannes is the right one to answer this question.
Anything helpful in this thread?
Hi everyone,
Just wondering if you tried reinstalling the software on your computer?
I had a similar problem, everything worked one day and then the next it just stopped working, no changes were made as far as I could tell (from one day to the next). Initially I feared it may have been a hardware issue; however, I nuked all the axoloti software on my computer (Mac/OSX at the time) and reinstalled everything and I was back in business. If you are using a Linux-based system make sure you set properly the user permissions and udev rules for usb connectivity.
(If you don't know how to do this let me know and I'll walk you through it)
Additionally, if you have not already tested this, try connecting the axoloti core with a different USB cable, preferably a high quality data capable cable. If you've already tried this try again with another cable. My axoloti has been finicky with cables that otherwise function with some of my other dev boards.
If LEDs are coming online when the board is powered up odds are the hardware is functioning properly and there is a miscommunication between the board and your computer. In my experience it would be pretty difficult to damage the axoloti hardware unless you were doing something reckless (ie. injecting voltages where you shouldn't, or going well outside of voltage tolerances). That having been said there is the outside chance that your board suffered static shock damage. This could occur if you were handling the raw pcb without proper grounding (to yourself or the board). Though the dangers of this are real they are generally exaggerated and I would look elsewhere first.
Lastly, and if you didn't read into the thread linked by @spacelordmother, if all else fails try this:
