Hi there - new to the Axoloti and new to the forum.
Could someone please shed some light on how to achieve the following:
Every quarter note, a potential free contact shall be switched for a few milliseconds.
Background: I'd like to "manually sync" the play/record/stop commands of several Digitech Jammans to midi clock. The electric path could be serial, something like
"tactswitch ==> potential free switch (Axoloti, potential free contact, pulsed every quarter note) ==> Jamman's footswitch contacts"
The Jamman receives its signal, when both the tactswitch and the Axoloti are switched. For live usage, you would keep the tactswitch pressed slightly before the next quarter note and - bang - the Jammans were exactly synced. This would be great.
Still have to find out, whether the Jamman's footswitch is normally open or normally closed.
So my questions are:
* Is this possible at all?
* Which Axoloti GPO would you use?
* I think, the output delivers +3.3 V (non-potential free). Could/would you apply a photomos-relais to translate the voltage into a potential free contact?
* What are the basic required patching objects?
Thanks in advance!
PS: If Axoloti could be a multitrack looper with track saving capabilities I would not think further about using the Jammans. ; )
