Hi!
I want to interface my Axoloti with my eurorack, but I don't have electronics knowledge for make an op-amp scaling.
The idea is to buy a couple of utility modules from Doepfer.
One is for scaling the 3.3 v analog out, to something more suitable for eurorack (5v), for send gates :
http://www.schneidersladen.de/en/doepfer-a-183-3-dc-coupled-amplifier.html
And another little utility module for make the audio out of axoloti to work at modular levels:
http://www.schneidersladen.de/en/doepfer-a-119-external-input.html
The idea is to use axoloti as a midi controlled oscillator, this oscillator audio goes to my eurorack, for being filtered, and the gate out is for trigger the amp and filter envelopes of my eurorack
What do you think ?
Cheers
There is cheaper tube amplifier but with the tube inside (probably the same sound but...
). i'm pretty sure it need an uncommon or extra power supply. Metasonix has a noisy reputation. Erica fusion mixer looks good but a bit overpowered for this idea. Elby design seems a good idea if i swallow the dream of having two glowing lamps on a synth.
