Hi everibody,
at longer time agoe i want finisch a projekt on win10.
Last work with axo patcher maybe 2020.
At this time the patching soft has several errors.
Axo Helpdesk and report tell me nothing.
All Demos and sketches include this errors
and dont uploadet and generate a start file on sd.
USB device found
connected
Authentic Axoloti Core
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
Start uploading file to sdcard : /WESCOFOR-02.axp
file error: FR_NO_FILESYSTEM, filename:""
Failed uploading file
java.lang.NullPointerException
at axoloti.object.AxoObjectInstanceAbstract.resolveType(AxoObjectInstanceAbstract.java:186)
at axoloti.Patch.PostContructor(Patch.java:364)
at axoloti.PatchGUI.PostContructor(PatchGUI.java:771)
at axoloti.PatchGUI.OpenPatchInvisible(PatchGUI.java:1006)
at axoloti.PatchGUI.OpenPatch(PatchGUI.java:1025)
at axoloti.MainFrame.actionPerformed(MainFrame.java:1206)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:833)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:877)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
uploading: /WESCOFOR-02.axp
uploading : 77%
file error: FR_INVALID_OBJECT, filename:""
uploading : 100%
file error: FR_INVALID_OBJECT, filename:"/"
Thanks for Hints
