NOTE: This is with the Experimental branch
When adding a new patch/patcher and editing the instance name I get the following stack trace:
axoloti.patch.object.AxoObjectInstancePatcher.setInstanceName(java.lang.String),java.lang.reflect.InvocationTargetException
	at sun.reflect.GeneratedMethodAccessor99.invoke(Unknown Source)
	at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at axoloti.property.PropertyReadWrite.set(PropertyReadWrite.java:50)
	at axoloti.mvc.AbstractController.setModelUndoableProperty(AbstractController.java:145)
	at axoloti.patch.object.ObjectInstanceController.changeInstanceName(ObjectInstanceController.java:55)
	at axoloti.swingui.patch.object.AxoObjectInstanceViewAbstract.handleInstanceNameEditorAction(AxoObjectInstanceViewAbstract.java:303)
	at axoloti.swingui.patch.object.AxoObjectInstanceViewAbstract$3.keyPressed(AxoObjectInstanceViewAbstract.java:335)
	at java.awt.Component.processKeyEvent(Component.java:6497)
	at javax.swing.JComponent.processKeyEvent(JComponent.java:2832)
	at java.awt.Component.processEvent(Component.java:6316)
	at java.awt.Container.processEvent(Container.java:2239)
	at java.awt.Container.dispatchEventImpl(Container.java:2297)
	at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1954)
	at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:835)
	at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1103)
	at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:974)
	at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:800)
	at java.awt.Component.dispatchEventImpl(Component.java:4760)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:760)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:84)
	at java.awt.EventQueue$4.run(EventQueue.java:733)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:730)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
Caused by: java.lang.NullPointerException
	at axoloti.patch.object.AxoObjectInstancePatcher.setInstanceName(AxoObjectInstancePatcher.java:73)
