I'm having difficulty troubleshooting an error and would be greatly appreciative of any help I can get.
I have a patch made up of subpatches. All of the subpatches work individually, but when I try to make the patch live, I get the following output:
Generate code complete
Creating directory on sdcard : /Harvestworks Project 2
Done creating directory
Changing working directory on sdcard : /Harvestworks Project 2
Start compiling patch
BDIR = C:\Users\frank\DOCUME~1\axoloti/build
FIRMWARE = .
RM
APP
! C:\Users\frank\DOCUME~1\axoloti/build/xpatch.h.gch
. C:/Users/frank/Documents/axoloti/axoloti-factory/objects/wave/streamer.h
. c:\program files (x86)\axoloti\app\chibios\ext\fatfs\src\ff.h
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:37:18: error: expected ';' at end of member declaration
static const int PARAM_INDEX_Logic_space_"Less_space_Than"space1_Trigger_space_Value = 0;
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:37:42: error: expected unqualified-id before user-defined string literal
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:38:18: error: expected ';' at end of member declaration
static const int PARAM_INDEX_Logic_space_"Greater_space_Than"space1_Trigger_space_Value = 1;
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:38:18: error: redeclaration of 'const int rootc::PARAM_INDEX_Logic_space_'
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:37:18: note: previous declaration 'const int rootc::PARAM_INDEX_Logic_space_'
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:38:42: error: expected unqualified-id before user-defined string literal
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:39:18: error: expected ';' at end of member declaration
static const int PARAM_INDEX_Logic_space_"Equal_space_To"space1_Trigger_space_Value = 2;
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:39:18: error: redeclaration of 'const int rootc::PARAM_INDEX_Logic_space_'
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:39:42: error: expected unqualified-id before user-defined string literal
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:583:28: error: expected unqualified-id before user-defined string literal
;class instanceLogic_space_"Less_space_Than"space1{
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:5486:1: error: expected '}' at end of input
C:\Users\frank\DOCUME~1\axoloti/build/xpatch.cpp:581:1: error: expected unqualified-id at end of input
make: *** [C:\Users\frank\DOCUME~1\axoloti/build/xpatch.bin] Error 1
Compiling patch failed ( E:\Harvestworks Project 2.axp )
