Hey!
Some days ago I updated my Axoloti to the build from Github, which has been great in many ways. But today I tried opening an older larger patch, which used to work. But now I get this error every time I make the patch live. Dont now if it related to the update, but that is the ony ting I have changed. Anyway:
Error message:
/axoloti-master/build/xpatch.cpp:2487:6: error: 'net5' was not declared in this scope
I get a few of them, for net5, net6, net7, net10 and net30.
Any ideas?
) then it could you have changed your path since you last used it?
WIll try saving out later. If this doesnt work I will send you a copy of the patch... It is the same patch as you have seen before
