hello again , can someone tell me where can i get an enclosure file
Enclosure file for front panel
jestern
Hi is this allright.. In my AI seems like the distances don't match. Also you have sometimes 3mm sometimes 2mm holes. Can you explain? Thanks for the work
janvantomme
Most of the case is made with 3mm plexiglass.
Front panel where the Axoloti is mounted on is 2mm plexiglass so all connectors can be easily accessed.
