Hello,
My axoloti's audio input suddenly crashed for no reason, I was running the looper6 patch in the demos.
No sound comes in anymore and there is a continuous high-pitched noise. I'm bummed.
I tried running several other "audio in" patches in the factory presets but no sound seems to come in anymore (tried audio/inconfig, nothing in the vu meters whatever I modify).
It just seems like it died all of a sudden, and I don't know what to do about it.
It is only the second day I'm using the axoloti... It seems like a hardware issue.
I haven't touched the axoloti when it was running unless to plug/unplug jacks...
Edit : the whole "audio" part actually stopped working ; I tried with synth patches, the main out stopped working and the headphones output only work when the minijack is halfway in - the sound just stops when it's completely plugged.
Audio in and out stopped working altogether. Is there any way to do hardware diagnosis from the patcher and send it here to check what could be wrong ?
Edit 2 : it seems i've entered a multi-layered axoloti nightmare, now it automatically disconnects the device whenever I try to go live with a new patch in it.
I really don't understand what is happening, first the audio, now the whole thing itself...
USB device found
connected
java.lang.Exception: cpuserial has wrong length
at axoloti.HWSignature.Verify(HWSignature.java:111)
at axoloti.USBBulkConnection.connect(USBBulkConnection.java:315)
at axoloti.MainFrame.jCheckBoxConnectActionPerformed(MainFrame.java:727)
at axoloti.MainFrame.access$500(MainFrame.java:89)
at axoloti.MainFrame$8.actionPerformed(MainFrame.java:521)
at javax.swing.JToggleButton$ToggleButtonModel.setPressed(JToggleButton.java:308)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Container.processEvent(Container.java:2237)
at java.awt.Container.dispatchEventImpl(Container.java:2295)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4889)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4526)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4467)
at java.awt.Container.dispatchEventImpl(Container.java:2281)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)Ping: WaitSync Timeout, disconnecting now
Disconnect request
) fixed this issue. So perhaps even if you don't have a controller object set up, maybe try erasing your SD card and see if that works.
