Does anyone have any thoughts on duplication or partial-duplication of custom Axoloti object functionality in the Community Library?
I'm working on a set of LaunchPad integration objects, with functionality that partially duplicates that of @rbrt's LaunchPad objects. I'm taking a slightly different approach, but the basic concepts are the same, and I'm using parts of his code.
What are people's thoughts on how I should handle publishing these objects? Is the partial duplication a problem? Is it likely to cause confusion to users, and is this a problem, if so?
It also raises the question about attribution of code fragments. I try and give credit where due when I use parts of 3rd-party objects, both in comments in the code itself, and in object descriptions, but don't tend to do the same when using parts of factory content. What do other people do?
a|x
