Hi guys,
I'd like to have a look at the patcher software before I get my board. No problem if everything is (obviously!) silent. I Just want to get a headstart on how the user interface works.
I do however have trouble getting it to run. So the first question is. Can it do that without a board at all? The website is not that clear about it. It says you need the board to upgrade libraries but that is not the same as not running at all, or is it?
So what gives?
Just in case it should run here 's a bit of info:
I've installed Java V8 Update 121 build 1.8.0_121-813
This is the log I get:
Axoloti version : 1.0.12-0-g80370d2 build time : 02/02/2017 20:39:14 CET
Link to firmware CRC E95BAC96
Current user library does not match correct version master -> 1.0.12
Stash (stash) FAILED : community (1.0.12,anon)
org.eclipse.jgit.api.errors.NoHeadException: HEAD required to stash local changes
at org.eclipse.jgit.api.StashCreateCommand.getHead(StashCreateCommand.java:225)
at org.eclipse.jgit.api.StashCreateCommand.call(StashCreateCommand.java:242)
at axoloti.utils.AxoGitLibrary.createStash(AxoGitLibrary.java:247)
at axoloti.utils.AxoGitLibrary.upgrade(AxoGitLibrary.java:199)
at axoloti.MainFrame$4.run(MainFrame.java:327)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
Status : home : OK
Status: community (1.0.12,anon) : OK ( master,clean )
search path : C:\Users\Marc Brassé\Documents\axoloti\axoloti-factory\objects
search path : C:\Users\Marc Brassé\Documents\axoloti\objects
search path : C:\Users\Marc Brassé\Documents\axoloti\axoloti-contrib\objects
finished loading objects
