Disconnectiong board : WaitSync Timeout
Hello,
I am experimenting things with a 4 tracks loopstation patch, based on the lrec object. I added 2 filters and lfos to control them, and 2 stomp delay objects (and also a mixer).
I experiment the patch using through patcher as I have no midi controller.
After a while (from seconds to some minutes),and somehow randomly, I have a disconnect request issue. The looper keeps playing and I have to connect the board again.
I tried to format the sd card with util/format (with success).
I 've tested with various usb wires, shaked a little bit the plug and it looks OK.
Note that before disconnecting Patcher begins to get slow an lags.
Is it a SRAM overload? DSP looks OK.
Thank you for your help, I have a lot to learn!
I am with 1.0.12, brand new board (flashed last month) on Xubuntu 18.04
Here are the logs (I found some threads quoting them but with no help for me).
Disconnect request
java.lang.InterruptedException
at java.lang.Object.wait(Native Method)
at java.lang.Object.wait(Object.java:502)
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1315)
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1296)
at javax.swing.SwingUtilities.invokeAndWait(SwingUtilities.java:1348)
at axoloti.USBBulkConnection.DistributeToDisplays(USBBulkConnection.java:1079)
at axoloti.USBBulkConnection.processByte(USBBulkConnection.java:1258)
at axoloti.USBBulkConnection$Receiver.run(USBBulkConnection.java:868)
at java.lang.Thread.run(Thread.java:748)
this is most likely an issue with the patcher, not the board. i have this disconnect requests also, mostly when i turn a dial the first time after the patch goes live. i then take it live again and that cures the problem. this works on OSX
thx for your answer, but unlike @lokki, patcher (or my patch) keeps disconnecting the board, even after the first attempt. Is it linked to a power limitation of my computer ram? tweaking too much through patcher?
Another clue for this issue?
Thank you!
Now I can affirm that is not due to one particular patch since the same Waitsync timeout disconnection request occurs while running other patches (somehow randomly).
Thx for your help
I was having that error and It was because of using more than 8 modulation sources. The solution was to add the extra modulation sources in the view/settings menu.
I'm not sure what causes this error, but it does happen to me a lot too.
To me it seems like there's a problem in the communication with the computer over the usb at moments that the patcher uses more cpu on the computer or something like that. I noticed it happening more when I have a game opened in chrome, that runs on java. So perhaps java itself is the culprit..
I once asked a friend for help, but as soon as I told him it ran on java, he laughed and walked away..
Hello, thank you for your ideas and feedback.
I tried this afternoon to increase modulation sources and it has disconnected once and no more then. I can tweak as much as my mouse allows me!
@servandisco, I didn't see this option before. Just to understand, is it saving sram to adjust to the exact amount of modulation? (and sources), something to do with scanning parameter changes?
Hi @Quentin , yes, the amount of presets and modulations have an influence on Sram.. I'm not super techy but I did read that trick once in some "saving sram" topic and I apply it myself now as I hit more frequently the sram limit than the cpu one..
Here is the thread: https://sebiik.github.io/community.axoloti.com.backup/t/saving-sram-tips/4412/9
happy patching!
S
