I'm having a weird persistent issue with taking patches live. My device behaves normally for small patches that compile quickly, but often disconnects suddenly when larger patches are used (especially containing subpatches). I've run into the SRAM limitations and cleaned things up, removed preset allocations, so it's not that. In fact, there's no error message at all and it's left me scratching my head. Here's a sample output (abridged for clarity):
USB device found
connected
Authentic Axoloti Core
Firmware version: 1.0.0.1, crc=0x12D13CA6, entrypoint=0x20011000
Generate code complete
Start compiling patch
arm-none-eabi-objcopy -O binary /Users/matthew/Documents/axoloti/build/xpatch.elf /Users/matthew/Documents/axoloti/build/xpatch.bin
Done compiling patch
Start uploading patch
bin path: /Users/matthew/Documents/axoloti/build/xpatch.bin
block uploaded @ 0x20011000 length 32768
block uploaded @ 0x20019000 length 11056
Done uploading patch
Start starting patch
Disconnect request
Done starting patch
Start locking
Done locking
As you can see, everything goes normally up to the Disconnect request after uploading. The behavior seems semi-random, as the same patch will sometimes load successfully and sometimes fail after changing nothing. I have noticed that I can sort of tell when it's going to fail by the "rhythm" or timing of the output – something is taking longer than it should perhaps. That seems strongly suggestive to me of a race condition, but I couldn't be sure which part.
After the output finishes, the patch returns to editable mode after flashing "live" for a fraction of a second, and the Axoloti window shows the "connect" button in the inactive state. Clicking "connect" will sometimes successfully reconnect and sometimes cause the program to hard freeze for 30 seconds or so, afterwards it usually spits out a message, I think about the serial number or firmware (though I couldn't repro to grab the error message just now). After the latter error, it requires the board to be physically disconnected and reconnected before it will work again.
Anyway, I've been able to work around this in the past by being patient and trying to compile several times, but my latest patch simply won't go live on the board, so here I am. Are there any known issues like this? How can I further debug?
Just some quick system details: I'm on a 2011 Macbook Pro, OS X 10.10.1, connecting directly via USB (no hub). I'm using the 1.0.6 build, though I recall seeing the same thing on 1.0.4.
Thanks kindly!
