hello everbody,
im making a dial matrix synth and i have the following problem.
the gpio's are skipping when i switch.this is not the case with the ctrl/dial object so it is hooked.
i have the problem the gpio is moving like 0.05 but it is enough to make the button skip after i switched.
I tried smooth object and kfilters but it is not enough,still 0,02 remains .and this also is enough to skip:
i seen some solutions but tried them almost all. Except the capacitors,what i ordered to be sure, but been told it is not my problem most likely.
im using:
10 x 10 K linear pots
all is grounded
2 switches (on ground ,before vdda,no differnce)
4 rotary switches,only 2 really connected with the resistor chain,2 are connected to ground,vdda and gpio(before not connected ,no difference)
there is nothing disconnected
everyhing is on VDDA
DIAL MATRIX SYNTH FOR PANEL3.axp (98.4 KB)
