So only one of my analog pots are working and I don't feel like opening up the case to resolder things, so I'm trying to use one analog pot for two different things. Right now I can do a gpio analog in through a demux and use a mini switch to swap the demux output.
The problem is, when I switch which line the pot is controlling the settings revert. Is there a way to have it hold the value when cutting off the constant feed?
for note, im running the pot into two sss/dist/boost that I kind of use for master volume for two different lines at the end of my chain (couldn't find a mix with inlets)
