I've been reading-up on the status regards Axoloti recording/playback to/from SD card.
As far as I can tell, that area is a bit hit and miss right now. I'd love to build a multi-track recorder, and while it sounds as if that's already possible, I also get the impression that full-duplex operations using the SD card are not refined enough yet. So personally, I would love to see that sort of stuff getting more attention. I think as long as it's capable of recording at least two mono tracks of audio, while simulataneously playing at least four mono tracks, then you would at least have an official standard set of objects for Axoloti that are specifically designed to deal with that stuff.
Dedicated objects for such things would ideally have inlets for modulating sample position, and outlets for retrieving it. Inlets for dictating recording modes such as overdub etc. I know these things exist already in one way or another, but they don't exist as dedicated full-duplex SD card related objects for building things like multi-track recorders etc.
