Yes that makes sense, thanks for moving it
I also respectfully disagree with you. It is not related to execution order, but basic mixing rules in any studio set up!
Below is an example..... If you are in doubt about this do a google search to have it confirmed.
It will cause problems if you for example have a mixer, set up with a send for a delay effect. If the delays internals mix is not set to 100%, it will leak some of the original signal and mix it back with the clean original signal path. That is a very known issues in any studio set up. If you for example have a Lexicon delay on the send on the mixer, you always set the mix of the Lexicon on 100% or else it will cause phase issues. If you dont do that, the 2 signals, the clean signal and the leaked signal from the send effect collide and cause phase issues. ANd this is the same with Axoloti. And it will cause problems in many cases.
Thanks, Jaffa
