I saved this file this afternoon and shut down the axoloti editor without any problems. But somehow I can't read open the patch now and I just don't see what is the problem. When opening the file in notepad, it looks like nothing of the code is missing..
javax.xml.stream.XMLStreamException: ParseError at [row,col]:[336,37]
Message: The entity name must immediately follow the '&' in the entity reference.
at com.sun.org.apache.xerces.internal.impl.XMLStreamReaderImpl.next(XMLStreamReaderImpl.java:604)
at com.sun.xml.internal.stream.XMLEventReaderImpl.nextEvent(XMLEventReaderImpl.java:83)
at org.simpleframework.xml.stream.StreamReader.read(StreamReader.java:110)
at org.simpleframework.xml.stream.StreamReader.next(StreamReader.java:94)
at org.simpleframework.xml.stream.StreamReader.peek(StreamReader.java:77)
at org.simpleframework.xml.stream.NodeReader.readText(NodeReader.java:258)
at org.simpleframework.xml.stream.NodeReader.readValue(NodeReader.java:235)
at org.simpleframework.xml.stream.InputElement.getValue(InputElement.java:201)
at org.simpleframework.xml.core.Primitive.read(Primitive.java:163)
at org.simpleframework.xml.core.Primitive.readElement(Primitive.java:207)
at org.simpleframework.xml.core.Primitive.readElement(Primitive.java:189)
at org.simpleframework.xml.core.Primitive.read(Primitive.java:124)
at org.simpleframework.xml.core.Composite.readVariable(Composite.java:623)
at org.simpleframework.xml.core.Composite.readInstance(Composite.java:573)
at org.simpleframework.xml.core.Composite.readUnion(Composite.java:549)
at org.simpleframework.xml.core.Composite.readElement(Composite.java:532)
at org.simpleframework.xml.core.Composite.readElements(Composite.java:445)
at org.simpleframework.xml.core.Composite.access$400(Composite.java:59)
at org.simpleframework.xml.core.Composite$Builder.read(Composite.java:1383)
at org.simpleframework.xml.core.Composite.read(Composite.java:201)
at org.simpleframework.xml.core.Composite.read(Composite.java:148)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:190)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:167)
at org.simpleframework.xml.core.CompositeInlineList.read(CompositeInlineList.java:144)
at org.simpleframework.xml.core.CompositeListUnion.readElement(CompositeListUnion.java:189)
at org.simpleframework.xml.core.CompositeListUnion.read(CompositeListUnion.java:162)
at org.simpleframework.xml.core.Variable$Adapter.read(Variable.java:482)
at org.simpleframework.xml.core.Composite.readVariable(Composite.java:613)
at axoloti.PatchGUI.OpenPatchInvisible(PatchGUI.java:1003)
at axoloti.PatchGUI.OpenPatch(PatchGUI.java:1025)
at axoloti.MainFrame.actionPerformed(MainFrame.java:1206)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:842)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:886)
at java.awt.Container.processEvent(Container.java:2237)
at java.awt.Container.dispatchEventImpl(Container.java:2295)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4889)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4526)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4467)
at java.awt.Container.dispatchEventImpl(Container.java:2281)
pfieuw!
