Control Transfer Failed -9
I'm building a step sequencer patch, using the Akai MIDImix as a controller on the USB host port. Everything worked fine so far, but now I'm getting a "Control Transfer Failed -9" error when adding new midi/in/cc objects to my patch and then turning the according knobs on the controller when the patch is live. I'm already using a little over 40 midi/in/cc objects in the patch, but the MIDImix controller has a bunch more knobs and buttons which I'd like to use. Is there a limit on the amount of midi/in/cc objects one can have in a patch?
Here's my version information:
Axoloti version : 1.0.12-1-0-g4de2b632 build time : 08/02/2017 00:15:42 GMT
Link to firmware CRC E95BAC96
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
USB device found
connected
Authentic Axoloti Core
search path : /Users/admin/Documents/axoloti/axoloti-factory/objects
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
search path : /Users/admin/Documents/axoloti/objects
search path : /Users/admin/Documents/axoloti/axoloti-contrib/objects
finished loading objects
After further testing, I think it's related to modsource objects. As soon as I attach a new modsource to a midi/in/cc object, the error occurs.
The number of mod sources is defined in the patch settings.
D'oh! Totally forgot about those settings! Sorry!
