I plan on connecting one audio output channel to an amp with a shared power supply. The amp itself has a direct connection from the power supply ground to the Ground of the audio output ("sleeve" of the plug, I guess). Is it safe?
In axoloti, there is a resistor from the "Ground" of the audio output to the real power supply ground... If I connect to the amp's inputs, I will effectively shortcut the "audio ground" to the real power ground. Any problem? Any pointer to something I should look into/study?
To be precise, I plan on using this adafruit amp built around a MAX9744: https://www.adafruit.com/product/1752
By the way, I read this interesting thread: https://sebiik.github.io/community.axoloti.com.backup/t/might-have-fried-the-output-of-axo/573
Thanks!
