so I just soldered a couple of these things to my axoloti:
screw terminals
I connected the outer pins of the potentiometer to VDDA and GND and the inner pin to for example PC3. When I looked at the disp obect for PC3, the value was at max all the time. It didn't change at all when I turned the potentiometer. I tried this with a 50k and a 10k potentiometer. When I used the 50k one, the dial moved in a range of 0,5 for a whole turn of the potentiometer.
How do I get this to work? Is my board broken or do i need other potentiometers?
