Instruction set:
Data structure: complex_number
It's composed of two variables: int32_t real and int32_t imaginary
Example of variable declaration:
complex_number z1;
cplx_assign(int32_t real , int32_t imaginary , complex_number *z )
Stores inside the variable z (pointer), the complex number formed by the real part "real" and the imaginary part "imaginary".
Example:
cplx_assign(param_R1,param_I1,&z1);
real(complex_number *z )
Returns the real part of the complex number z.
Example:
disp_sumR = real(&z3);
imaginary(complex_number *z )
Returns the imaginary part of the complex number z.
Example:
disp_sumI = imaginary(&z3);
cplx_sum(complex_number *z1 , complex_number *z2 ** , complex_number *z3)**
Performs the sum z1 + z2, stores the result in the variable z3. (Pointers!)
Example:
cplx_sum(&z1,&z2,&z3);
cplx_subtract(complex_number *z1 , complex_number *z2 ** , complex_number *z3)**
Performs the sum z1 - z2, stores the result in the variable z3. (Pointers!)
Example:
cplx_subtract(&z1,&z2,&z3);
cplx_mul_Q27(complex_number *z1 , complex_number *z2 , complex_number *out )
Performs z1 * z2 in fixed point (using Q27 format) and stores the result into the variable "out"
cplx_mul_Q27(&z1,&z2,&z4);
cplx_div_Q27(complex_number *z1 , complex_number *z2 , complex_number *out )
Performs z1 / z2 in fixed point (using Q27 format) and stores the result into the variable "out"
cplx_div_Q27(&z1,&z2,&z5);
cplx_pow_Q27(complex_number *z , int32_t exp , complex_number *out )
Performs z^exp in fixed point (using Q27 format) and stores the result into the variable "out".
cplx_pow_Q27(&z1,param_exp,&z6);
cplx_scale_Q27(complex_number *z , int32_t scale , complex_number *out )
Performs a scalar multiplication between the complex number z and the integer scale (in fixed point, Q27 format) and stores the result into the complex number "out".
cplx_scale_Q27(&z1,param_rate,&z7);
cplx_interp_Q27(complex_number *z1 , complex_number *z2 , int32_t rate , complex_number *out )
Interpolates linearly between two complex numbers z1 and z2 and stores the result into the variable "out". The amount of interpolation is set by the integer "rate".
Rate = 0 outputs z1
Rate = (1<<27) outputs z2
cplx_interp_Q27(&z1,&z2,param_rate,&z8);
cplx_rotate(complex_number *z , uint32_t phase , complex_number *out )
Rotates the complex number z by an amount "phase" and stores the result in the variable "out".
The phase is expressed in unsigned int.
phase = 0 corresponds to 0
phase = (1<<29) corresponds to pi/4
phase = (1<<30) corresponds to pi/2
phase = (1<<31) corresponds to pi
phase = (1<<32) corresponds to 2pi
cplx_rotate(&z1,param_rate<<5,&z10);
cplx_rotate_cheap(complex_number *z , uint32_t phase , complex_number *out )
This one is slightly cheaper than the previous, it just reads the sine2t table, without interpolation.
cplx_rotate_cheap(&z1,param_rate<<5,&z10);
cplx_polar_Q27(complex_number *z , int32_t *modulo , uint32_t *phase )
Converts the complex number z in polar form, and stores the components in the integer variables "modulo" and "phase".
Phase follows the format i described above for the rotate function.
cplx_polar(&z10,&disp_mod,&phase);
cplx_cartesian(complex_number *z , int32_t *real_out , int32_t *imaginary_out )
Outputs the complex number z in cartesian form in the variables real_out and imaginary_out.
It's really just a condensation of the real() and imaginary() functions..
cplx_cartesian(&z4,&disp_mulR,&disp_mulI);
