Compiling firmware
getting this at the end of compile?
"setup build dir"
"Compiling firmware..."
'make' is not recognized as an internal or external command,
operable program or batch file.
"Compiling firmware flasher..."
Link to firmware CRC E5C6C240
Done compiling firmware
You're on windows I guess?
What's your motivation to compile firmware? Normally this is not needed. The menu item to compile firmware should have been invisible, that is a known issue (of today).
also can you confirmed you installed the runtime, as described in this thread : https://sebiik.github.io/community.axoloti.com.backup/t/installing-on-windows
you should have the directory C:\Program Files (x86)\axoloti_runtime\platform_win
whilst you won't need it to compile the firmware, as that is already supplied built, you will need it to compile patches.
EDIT: Ive pushed a fix, so the user will be informed if its not been correctly installed... I guess for 1.0.2 ?
sorry yep wrong folder works like a charm. many thanks for your help
