Overview
Errors that might occur when you take a patch live, you will see a RED error message at the bottom:
Compiling patch failed (~Documents/axoloti/mypatches/test.axp )
If you then look a few lines up, will see the cause of the error, listed before are the common ones and how to resolve.
Errors
CCMSRAM overflowed by 85792 bytes
The Axoloti board has a finite amount of memory (like us all) called SRAM. If you compile a patch that uses too much, it will give the above error (number will be different).
This is caused by allocating too much space for things like delay lines/tables.
FIX: reduce delay line/table sizes and try again, or move them to SDRAM of which there is much more!
(you will find sdram variants of most  write objects)
sdram overflowed by 971520 bytes
Like above, the Axoloti has a finite amount of SDRAM (though much more than SRAM), if you compile a patch that uses too much it will give the above error (number will be different)
FIX: reduce delay line/table sizes and try again.
Finding the origin of other compilation errors
Often the error message will point out which object is causing the compilation error. Here is how to recognize this:
In member function void rootc::instanceread__1::dsp(int32_t, int32_t (&)[16], int):
C:\Users\jtaelman\Documents\axoloti/build/xpatch.cpp:54:29: error: class rootc has no member named instancesdfdsafd_i
This error points to an object with instance name "read_1". In this particular case it refers to a non-existing object.
