I've created a harmonizer that is capable of pitch shifting the incoming audio into a 7th chord according to the midi note input. The chord is built on the played note. You can select scale (major/minor) and tonic.
This is another take on my previous project Poly-Box emulation.
Designed to work with Hohum Lab Axoctrl knob/button layout.
How to make it work:
- feed continues tone (drone) in to the axoloti left audio in
- press tune button (button 7) to switch to tune mode
- set the audio in pitch (knob 8) and gain (knob 16) - you will hear pilot tone and the note number will be visible on display, scope will present audio in signal
- press tune button to switch back to play mode
- set envelope parameters (knobs 10-13)
- play on your keyboard
4 voices (70% DSP used)
Patch is available on my github: chord_box.axp
