hi there, i coded an object that outputs choosen values if the input is equal to certain values. (kind of like a special case of select in puredata) can somebody have a look why if there is no hit (no numbers match) there is still the first value output? i would expect the value to stay the same as the last "hit" but it always bounces to the first when there is no match...
find attached the object.
==output.axo (1.6 KB)
