Hello everyone, I'm Italian and my English is not perfect.
Sorry
Soon I buy a axoloti but I have a question.
Is it possible to change the "pitch" or "tone" of a sample Wav?
I think there is a need for tables.
has anyone already done this?
Change "pitch" sample WAV
ianni992
jaffasplaffa
Did you check the facotry library?
There are tables, both non-interpolated tables as well as interpolated tables, the are basic play tables and more "real" tables. So table side is covered.
If you just want simple playback of a sample and the ability to change the pitch of that sample, try out te object called table/play pitch, it does exactly that. There are help files to get you started, push the small triangle in the top right corner of the object and push "help".
