.. And I'm feeling proud as a cat with a mouse!
This happened when triggering samples with a Korg Nanopad 2.
Control transfer failed: -7
connected
java.lang.Exception: cpuserial has wrong length
at axoloti.HWSignature.Verify(HWSignature.java:96)
at axoloti.USBBulkConnection.connect(USBBulkConnection.java:321)
at axoloti.MainFrame.jCheckBoxConnectActionPerformed(MainFrame.java:769)
at axoloti.MainFrame.access$400(MainFrame.java:80)
at axoloti.MainFrame$7.actionPerformed(MainFrame.java:410)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2346)
at javax.swing.JToggleButton$ToggleButtonModel.setPressed(JToggleButton.java:308)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6525)
at java.awt.Component.processEvent(Component.java:6290)
at java.awt.Container.processEvent(Container.java:2234)
at java.awt.Component.dispatchEventImpl(Component.java:4881)
at java.awt.Container.dispatchEventImpl(Container.java:2292)
at java.awt.Component.dispatchEvent(Component.java:4703)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4898)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4533)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4462)
at java.awt.Container.dispatchEventImpl(Container.java:2278)
at java.awt.Window.dispatchEventImpl(Window.java:2750)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:86)
(my kittens do all the time!)
