I am running on Windows 10, 64-bit, with the latest updates on a quad-core AMD laptop.
JRE is version 8, rev 144.
No patches will compile. Here is the Axo command window:
Axoloti version : 1.0.12-0-g80370d2 build time : 02/02/2017 20:39:14 CET
Link to firmware CRC E95BAC96
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
USB device found
not accesseable : -12
USB device found
connected
Authentic Axoloti Core
search path : C:\Users\Greg O'Drobinak\Documents\axoloti\axoloti-factory\objects
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
search path : C:\Users\Greg O'Drobinak\Documents\axoloti\objects
search path : C:\Users\Greg O'Drobinak\Documents\axoloti\axoloti-contrib\objects
finished loading objects
Generate code complete
Start compiling patch
BDIR = C:\Users\GREGO'~1\DOCUME~1\axoloti/build
FIRMWARE = .
RM
rm: cannot remove C:\\Users\\GREGO~1\\DOCUME~1\\axoloti/build/xpatch.o C:\\Users\\GREGO~1\\DOCUME~1\\axoloti/build/xpatch.elf': Invalid argumentC:\Users\GREGO~1\DOCUME~1\axoloti/build/xpatch.bin C:\Users\GREGO~1\DOCUME~1\axoloti/build/xpatch.d': Invalid argument
rm: cannot remove
rm: cannot remove `C:\Users\GREGO~1\DOCUME~1\axoloti/build/xpatch.map C:\Users\GREGO~1\DOCUME~1\axoloti/build/xpatch.lst': Invalid argument
make: *** [C:\Users\GREGO'~1\DOCUME~1\axoloti/build/xpatch.bin] Error 1
Compiling patch failed ( C:\Users\Greg ODrobinak\Documents\axoloti\axoloti-factory\patches\tutorials\14_additive_inharmonic.axp )
There are only three files in the build directory:
xpatch.cpp
xpatch.h.d
xpatch.h.gch
Can you please give some recommendation as how to solve this?
Many thanks!
) we use Make to do the compilation.
