Can"t connect anymore?!
last week everything was fine. Went to use today and I'm getting this message.
USB device found
connected
java.lang.Exception: cpuserial has wrong length
at axoloti.HWSignature.Verify(HWSignature.java:111)
at axoloti.USBBulkConnection.connect(USBBulkConnection.java:315)
at axoloti.MainFrame.jCheckBoxConnectActionPerformed(MainFrame.java:727)
at axoloti.MainFrame.access$500(MainFrame.java:89)
at axoloti.MainFrame$8.actionPerformed(MainFrame.java:521)
at javax.swing.JToggleButton$ToggleButtonModel.setPressed(JToggleButton.java:308)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
Control transfer failed: -7
Disconnect request
I'm on a MacBook Pro 10.13.6
any ideas?
installed on a diffrent computer. Imac...
same message.
Hello. Do the two LEDs flash when power is applied? They flash back and forth,with the left one staying on.
After:
USB device found
connected
you get:
Authentic Axoloti Core
The Java error messages are from the patcher software. My thoughts are: is this 'corrupted' firmware or a hardware failure? The USB connected suggests the client USB chip is ok, but not the MCU?
Is your Axoloti just the bare-board or is it in a case? Perhaps there was ESD damage from handling it?
Thanks for your reply. Somehow it appears the sd card became corrupted?!The card is only a week old with two saves to it.With the card removed it's connecting. Will try to reformat the card and retry.
Thanks again.
That's a relief. So if it gets stuck reading the SD card during boot-up, that's it. No further communication and the Patcher throws a terminal-looking error.
Yeah. With the cpuserial errors I though something had fried somehow. So glad it was the card. I just got this thing! Live and learn.
