See pic. It's in the way of my build (crashes with a toggle on an enclosure I've spent a week making) and I'd like to remove it. Can I just remove it, or will it make the whole board not work? I have no use for it in my build.
Can I break off this USB input?
lokki
It is the USB host port, so you can remove it if you don't need it. Just make sure you don't short out any of the connections when you remove the port, and don't damage any nearby SMD components
