I tried to open a patch from Dropbox, I now get the following error on file/open (except when opening recent files)
Saving preferences...
preferences path : /Users/michiel/Documents/axoloti/axoloti.prefs
java.lang.ClassNotFoundException: is-copy-enabled
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.simpleframework.xml.strategy.Loader.load(Loader.java:50)
at org.simpleframework.xml.strategy.TreeStrategy.readValue(TreeStrategy.java:163)
at org.simpleframework.xml.strategy.TreeStrategy.read(TreeStrategy.java:102)
at org.simpleframework.xml.core.Source.getOverride(Source.java:360)
at org.simpleframework.xml.core.Factory.getConversion(Factory.java:207)
at org.simpleframework.xml.core.Factory.getOverride(Factory.java:139)
at org.simpleframework.xml.core.ObjectFactory.getInstance(ObjectFactory.java:63)
at org.simpleframework.xml.core.Composite.read(Composite.java:139)
at axoloti.MainFrame.OpenPatch(MainFrame.java:1124)
at axoloti.MainFrame.OpenPatch(MainFrame.java:1117)
at axoloti.PatchFrame.jMenuOpenActionPerformed(PatchFrame.java:676)
at axoloti.PatchFrame.access$300(PatchFrame.java:60)
at axoloti.PatchFrame$7.actionPerformed(PatchFrame.java:381)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2346)
at com.apple.laf.ScreenMenuItem.actionPerformed(ScreenMenuItem.java:125)
at java.awt.MenuItem.processActionEvent(MenuItem.java:669)
at java.awt.MenuItem.processEvent(MenuItem.java:628)
at java.awt.MenuComponent.dispatchEventImpl(MenuComponent.java:351)
at java.awt.MenuComponent.dispatchEvent(MenuComponent.java:339)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:761)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:86)
