Hello, sorry to ask a beginner question - I've been doing some tutorials and searching the forum for a while, but still no luck.
I'm coming from a pure data and max background, and finding it hard work switching to the axo. I'd forgotten what's its like learning a new language and not knowing the most basic things....
I would like to take a midi note and convert it to a float (so I can send it to the phase input of factotum). I want to hit a key, e.g. 60, and I want the object to output 0.25, then for key 61, I'd like 0.50, etc.
I've looked through the midi objects, math, and other categories of objects, but I've still not found a selection of objects to help build this.
I did find this note to cc converter - I just couldn't find a float object that I could bang the output of (based on a condition)
So, here's some specific questions:
1) what's the simplest way to trigger/output a float based on a midi note a) some existing objects (like the above note to cc converter) if so which objects would I need? b) case select within a patch/object or the midi/in/script object, c) using a table , I will need 6 mappings in total.
2) are there any guides or tips for anyone from a pd background?
