Is there anything I need to do or consider? My last board got fried after I removed the MIDI board (pre soldering anything, so it might have happened due to soldering) even though I followed the 'perforated line' between the main board and the Midi board, so now that I've got the entire board wired up and working I'm terrified of it happening again. It needs to go because of the enclosure size.
Side question, can I somehow install a normal DC input after I remove the MIDI board, and if so... Give me the deets pls! USB is fine for home use, but if I want it on my board I'd prefer just having it run on a normal DC barrel.
Thanks in advance!
