Little video inspired about this post https://sebiik.github.io/community.axoloti.com.backup/t/ciat-lombarde-instruments/532
Axoloti - volume change 7 sine oscillators
keyman
I did struggle about midi cc controlling say a mix object gain directly or math/gain, too zipper noise /stepping too high?
johannes
After using math/exp as a waveshaper on a sine-wave, the signal is heavily asymmetrical and has a strong DC offset. Changing gain on such signal reveals zipper noise more than on many other signals.
The mix objects do not interpolate (or camouflage zipper noise) at all.
A way around would be using vca objects, and "const/dial p" for midimapped control. Further smoothing can be obtained with a k-rate filter.
