The Axoloti patcher stopped working properly my office iMac yesterday.
Here's the Console window (screenshot taken this morning, the problem first occurred yesterday):
It seems to stick at this point. Though it is possible to create a new document, I'm not able to make the object browser to appear.
I get this when attempting to open a document from disk.
Axoloti version : 1.0.10-0-gf8ed51d build time : 10/05/2016 19:56:36 UTC
Link to firmware CRC 3DB31696
Saving preferences...
preferences path : /Users/adrin009/Documents/axoloti/axoloti.prefs
java.lang.NullPointerException
at axoloti.object.AxoObjectInstanceAbstract.resolveType(AxoObjectInstanceAbstract.java:179)
at axoloti.Patch.PostContructor(Patch.java:313)
at axoloti.PatchGUI.PostContructor(PatchGUI.java:817)
at axoloti.PatchGUI.OpenPatchInvisible(PatchGUI.java:1035)
at axoloti.PatchGUI.OpenPatch(PatchGUI.java:1054)
at axoloti.FileUtils.Open(FileUtils.java:149)
at axoloti.menus.FileMenu.jMenuOpenActionPerformed(FileMenu.java:253)
at axoloti.menus.FileMenu.access$200(FileMenu.java:49)
at axoloti.menus.FileMenu$3.actionPerformed(FileMenu.java:105)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.AbstractButton.doClick(AbstractButton.java:376)
at javax.swing.AbstractButton.doClick(AbstractButton.java:356)
at javax.swing.plaf.basic.BasicMenuItemUI$Actions.actionPerformed(BasicMenuItemUI.java:802)
at javax.swing.SwingUtilities.notifyAction(SwingUtilities.java:1663)
at javax.swing.JComponent.processKeyBinding(JComponent.java:2882)
at javax.swing.JMenuBar.processBindingForKeyStrokeRecursive(JMenuBar.java:699)
at javax.swing.JMenuBar.processBindingForKeyStrokeRecursive(JMenuBar.java:706)
at javax.swing.JMenuBar.processKeyBinding(JMenuBar.java:677)
at javax.swing.KeyboardManager.fireBinding(KeyboardManager.java:307)
at javax.swing.KeyboardManager.fireKeyboardAction(KeyboardManager.java:293)
at javax.swing.JComponent.processKeyBindingsForAllComponents(JComponent.java:2974)
at javax.swing.JComponent.processKeyBindings(JComponent.java:2966)
at javax.swing.JComponent.processKeyEvent(JComponent.java:2845)
at java.awt.Component.processEvent(Component.java:6310)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.KeyboardFocusManager.redispatchEvent(KeyboardFocusManager.java:1954)
at java.awt.DefaultKeyboardFocusManager.dispatchKeyEvent(DefaultKeyboardFocusManager.java:806)
at java.awt.DefaultKeyboardFocusManager.preDispatchKeyEvent(DefaultKeyboardFocusManager.java:1074)
at java.awt.DefaultKeyboardFocusManager.typeAheadAssertions(DefaultKeyboardFocusManager.java:945)
at java.awt.DefaultKeyboardFocusManager.dispatchEvent(DefaultKeyboardFocusManager.java:771)
at java.awt.Component.dispatchEventImpl(Component.java:4760)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
I deleted the prefs file, flushed the OS X plist cache, and restarted the Patcher. Seems to work fine now, so I guess the prefs file must have been corrupted somehow.
I can't attach the prefs file, since it's not of one of the allowed types, but here is the content:
<preferences appVersion="1.0.10">
<CurrentFileDirectory>/Users/adrin009/Documents/axoloti/toneburst.private/objects/toneburst/osc/talkie</CurrentFileDirectory>
<PollInterval>50</PollInterval>
<MouseDialAngular>false</MouseDialAngular>
<ExpertMode>false</ExpertMode>
<recentFiles>
<string>/Users/adrin009/Documents/axoloti/axoloti-factory/objects/seq/lfsrseq.axh</string>
<string>/Users/adrin009/Documents/axoloti/axoloti-factory/objects/math/more_math.axh</string>
<string>/Users/adrin009/Documents/axoloti/axoloti-factory/objects/math/math.axh</string>
<string>/Users/adrin009/Documents/axoloti/toneburst.private/objects/toneburst/osc/canto/canto.axh</string>
<string>/Users/adrin009/Documents/axoloti/axoloti-contrib/patches/jt/grainy-table.axp</string>
<string>/Users/adrin009/Documents/axoloti/axoloti-contrib/patches/jt/devel/cic_oscillator_workbench.axp</string>
<string>/Users/adrin009/Desktop/range-test.axp</string>
<string>/Users/adrin009/Documents/axoloti/toneburst.private/objects/toneburst/osc/canto/canto_demo.axh</string>
<string>/Users/adrin009/Documents/axoloti/toneburst.private/objects/toneburst/osc/canto/canto_demo.axp</string>
<string>/Users/adrin009/Documents/axoloti/toneburst.private/patches/toneburst/osc/canto_demo.axp</string>
<string>/Users/adrin009/Documents/axoloti/axoloti-contrib/patches/jt/devel/float_workbench.axp</string>
<string>/Users/adrin009/Documents/axoloti/toneburst.private/objects/toneburst/osc/talkie/Talkie Synth.axp</string>
<string>/Users/adrin009/Documents/axoloti/toneburst.private/objects/toneburst/osc/talkie/talkie.axh</string>
<string>/Users/adrin009/Documents/axoloti/toneburst.private/objects/toneburst/osc/talkie/Talkie Controller.axp</string>
<string>/Users/adrin009/Documents/axoloti/toneburst.private/objects/toneburst/osc/talkie/talkie 3.axh</string>
<string>/Users/adrin009/Documents/axoloti/axoloti-contrib/patches/jt/devel/updownsampler_x4.axp</string>
</recentFiles>
<RuntimeDir>/Applications/axoloti_runtime</RuntimeDir>
<FirmwareDir>/Applications/Axoloti.app/Contents/Java/firmware</FirmwareDir>
<FavouriteDir></FavouriteDir>
<ControllerObject></ControllerObject>
<ControllerEnabled>false</ControllerEnabled>
<gitlib>
<Id>factory</Id>
<Type>git</Type>
<LocalLocation>/Users/adrin009/Documents/axoloti/axoloti-factory/</LocalLocation>
<Enabled>true</Enabled>
<RemoteLocation>https://github.com/axoloti/axoloti-factory.git</RemoteLocation>
<UserId></UserId>
<Password></Password>
<AutoSync>false</AutoSync>
<Revision></Revision>
<ContributorPrefix></ContributorPrefix>
</gitlib>
<filelib>
<Id>home</Id>
<Type>local</Type>
<LocalLocation>/Users/adrin009/Documents/axoloti/</LocalLocation>
<RemoteLocation></RemoteLocation>
<UserId></UserId>
</filelib>
<gitlib>
<Id>community</Id>
<Type>git</Type>
<LocalLocation>/Users/adrin009/Documents/axoloti/axoloti-contrib/</LocalLocation>
<RemoteLocation>https://github.com/axoloti/axoloti-contrib.git</RemoteLocation>
<UserId>toneburst</UserId>
<Password>REDACTED</Password>
<ContributorPrefix>toneburst</ContributorPrefix>
</gitlib>
<gitlib>
<Id>toneburst.Private</Id>
<Type>git</Type>
<LocalLocation>/Users/adrin009/Documents/axoloti/toneburst.private/</LocalLocation>
<RemoteLocation>https://github.com/toneburst/axoloti</RemoteLocation>
<AutoSync>true</AutoSync>
</gitlib>
</preferences>
Incidentally, I notice the GitHub password for any user repos is stored in plaintext in the prefs file (that's not my actual password, above). Not sure this is a good thing...
