Axoloti Patcher
macos
Hi guys, I have this really strange bug, whenever I connect to wifi or internet my .pref file gets deleted and replaced with the stock one. I have also noticed whenever I am in LIVE mode and try to change a parameter it works but if I am offline I get the following error:
Axoloti version : 1.0.12-2-0-g7975cc87 build time : 09/04/2018 13:15:31 GMT
Link to firmware CRC E95BAC96
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
USB device found
connected
Authentic Axoloti Core
search path : /Users/ed/Documents/axoloti/axoloti-factory/objects
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
search path : /Users/ed/Documents/axoloti/objects
search path : /Users/ed/Documents/axoloti/axoloti-contrib/objects
finished loading objects
Generate code complete
Creating directory on sdcard : /IN
Done creating directory
Changing working directory on sdcard : /IN
Start compiling patch
BDIR = /Users/ed/Documents/axoloti/build
FIRMWARE = .
RM
APP
! /Users/ed/Documents/axoloti/build/xpatch.h.gch
LINK
BIN
Done compiling patch
Start uploading patch
bin path: /Users/ed/Documents/axoloti/build/xpatch.bin
block uploaded @ 0x20011000 length 8320
Done uploading patch
Starting patch...
Done starting patch
Start locking
Done locking
Disconnect request
java.lang.InterruptedException
at java.lang.Object.wait(Native Method)
at java.lang.Object.wait(Object.java:502)
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1315)
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1296)
at javax.swing.SwingUtilities.invokeAndWait(SwingUtilities.java:1348)
at axoloti.USBBulkConnection.DistributeToDisplays(USBBulkConnection.java:1079)
at axoloti.USBBulkConnection.processByte(USBBulkConnection.java:1258)
at axoloti.USBBulkConnection$Receiver.run(USBBulkConnection.java:868)
I have tried reinstalling the patcher, I believe its a software issue or an issue with my Mac as I get the same error with my 2nd board. Any help will be much appreciated and thank you in advance.
