hi there,
first of all, the axoloti is great and thanks for your great work. also, this is my first post and i hope to do it right.
my problem: i could not get it running on 10.12 (macSierra)!
my first laptop is running 10.9 and everything is working fine. my second laptop is running 10.12 (and following the link java1.8 is installed) but i get some errors and i can´t work on 10.12.
i used the same and up-to-date installers on both machines. strangly, on 10.9 the folder in ~/documents/axoloti ist filled with nice patches and other stuff, but on 10.12 the folder contains the same folders (axoloti-contrib,axoloti-factory,axoloti.prefs,build,objects,patches) - but all of them are empty! i manually copied the folder from the 10.9 laptop to 10.12 laptop and - magic to me - i could upload 2 or 3 patches and play live for a short while. now, it disconnects every minute or so…and after a restart i get a new error.
i would be happy about any help, because now the axoloti is not useable for me and i can not stick to the 10.9 laptop any more.
thanks,
prxtst
i copied all information, i hope it helps:
this is a fresh install from 10.12. (before coping the files from 10.9, no board connected) :
Axoloti version : 1.0.12-1-0-g4de2b632 build time : 08/02/2017 00:15:42 GMT
Link to firmware CRC E95BAC96
Current user library does not match correct version master -> 1.0.12
Stash (stash) FAILED : community (1.0.12,anon)
org.eclipse.jgit.api.errors.NoHeadException: HEAD required to stash local changes
at org.eclipse.jgit.api.StashCreateCommand.getHead(StashCreateCommand.java:225)
at org.eclipse.jgit.api.StashCreateCommand.call(StashCreateCommand.java:242)
at axoloti.utils.AxoGitLibrary.createStash(AxoGitLibrary.java:247)
at axoloti.utils.AxoGitLibrary.upgrade(AxoGitLibrary.java:199)
at axoloti.MainFrame$4.run(MainFrame.java:327)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
Current factory library does not match correct version, upgrading master -> 1.0.12
Stash (stash) FAILED : factory (1.0.12,anon)
at axoloti.MainFrame$4.run(MainFrame.java:339)
Status: factory (1.0.12,anon) : OK ( master,clean )
Status : home : OK
Status: community (1.0.12,anon) : OK ( master,clean )
search path : /Users/ichi/Documents/axoloti/axoloti-factory/objects
search path : /Users/ichi/Documents/axoloti/objects
search path : /Users/ichi/Documents/axoloti/axoloti-contrib/objects
finished loading objects
this is from 10.12 after coping the files from 10.9, now it disconnects quite often:
Status : home : OK
Status: community (1.0.12,anon) : OK ( 1.0.12,clean )
USB device found
connected
Can't obtain signature, upgrade firmware?
Disconnect request
USB device found
connected
java.lang.Exception: otpinfo has wrong length
at axoloti.HWSignature.Verify(HWSignature.java:114)
at axoloti.USBBulkConnection.connect(USBBulkConnection.java:315)
at axoloti.MainFrame.jCheckBoxConnectActionPerformed(MainFrame.java:727)
at axoloti.MainFrame.access$500(MainFrame.java:89)
at axoloti.MainFrame$8.actionPerformed(MainFrame.java:521)
at javax.swing.JToggleButton$ToggleButtonModel.setPressed(JToggleButton.java:308)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
Disconnect request
USB device found
connected
Authentic Axoloti Core
Firmware version: 1.0.0.1, crc=0xE95BAC96, entrypoint=0x20011000
Disconnect request
and after a restart this is my new error message (10.12):
Status : home : OK
USB device found
connected
file error: FR_NO_FILE, filename:"/START.BIN"
Disconnect request
USB device found
connected
Generate code complete
Creating directory on sdcard : /01_sine_oscillator
Done creating directory
Changing working directory on sdcard : /01_sine_oscillator
Start compiling patch
BDIR = /Users/ichi/Documents/axoloti/build
FIRMWARE = .
RM
APP
! /Users/ichi/Documents/axoloti/build/xpatch.h.gch
LINK
BIN
Done compiling patch
Start uploading patch
bin path: /Users/ichi/Documents/axoloti/build/xpatch.bin
block uploaded @ 0x20011000 length 5160
Done uploading patch
Starting patch...
Done starting patch
Start locking
Done locking
Disconnect request
java.lang.InterruptedException
at java.lang.Object.wait(Native Method)
at java.lang.Object.wait(Object.java:502)
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1315)
at java.awt.EventQueue.invokeAndWait(EventQueue.java:1296)
at javax.swing.SwingUtilities.invokeAndWait(SwingUtilities.java:1348)
at axoloti.USBBulkConnection.DistributeToDisplays(USBBulkConnection.java:1079)
at axoloti.USBBulkConnection.processByte(USBBulkConnection.java:1258)
at axoloti.USBBulkConnection$Receiver.run(USBBulkConnection.java:868)
