I was asked to re-post the following to 'your projects' in hopes of sharing with more users. I have a large modular synth and became intrigued by the potential of the Axoloti being part of that system. Catch is, the modular runs audio at typically -5v to +5v, or more, which appears hazardous to the Axo. Also, most control voltages run 0 to +5 which also gets into trouble with the gpio inputs. So I needed to build an interface board to protect and level shift the various ins and outs to the Axo. Luckily, my modular is based on Moog units so the Axo board easily fits in a module space...
re-post:
Some progress made. The audio in (at the stereo jack) will take -1.65v to +1.65v before clipping which is consistent with the gpio inputs of 0 to +3.3v. For the gpio inputs I found some low voltage, rail-to-rail opamps and am amazed how well they work... never used them before. They're powered directly off the Axo board's gnd and +3.3v so any excess signal into the opamps clip perfectly at 0 and +3.3v. The bipolar audio input was trickier so I just ran them into 'normal' opamps powered at +-15v and set the gain such that they clip just after my desired, useful levels. Then let a pot take the signal down to safely enter the Axo's inputs. The dual Schottky diodes are probably not needed but they were cheap and might provide a little safety? At least now I'm comfortable plugging anything into the Axo. Which reminds me, I need to quit building stuff and start playing with it.
Thanks again!
