It's my second day with my axoloti core, and I can't connect it to the software anymore.
I've tried everything I could find in the community :
- uninstall drivers => unplug/replug hardware
- DFU mode => flash firmware (rescue)
- change usb cable
- change usb port
Axoloti's version : 1.0.10
PC : Windows 10
When I open the software I have this message :
USB device found
org.usb4java.LibUsbException: USB error 5: Unable to claim interface: Entity not found
_ at axoloti.USBBulkConnection.connect(USBBulkConnection.java:247)_
_ at axoloti.MainFrame.jCheckBoxConnectActionPerformed(MainFrame.java:655)_
_ at axoloti.MainFrame.access$400(MainFrame.java:82)_
_ at axoloti.MainFrame$6.actionPerformed(MainFrame.java:431)_
_ at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)_
_ at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)_
_ at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)_
_ at javax.swing.JToggleButton$ToggleButtonModel.setPressed(JToggleButton.java:308)_
_ at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)_
_ at java.awt.Component.processMouseEvent(Component.java:6535)_
_ at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)_
_ at java.awt.Component.processEvent(Component.java:6300)_
_ at java.awt.Container.processEvent(Container.java:2236)_
_ at java.awt.Component.dispatchEventImpl(Component.java:4891)_
_ at java.awt.Container.dispatchEventImpl(Container.java:2294)_
_ at java.awt.Component.dispatchEvent(Component.java:4713)_
_ at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)_
_ at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)_
_ at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)_
_ at java.awt.Container.dispatchEventImpl(Container.java:2280)_
_ at java.awt.Window.dispatchEventImpl(Window.java:2750)_
_ at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)_
_ at java.awt.EventQueue.access$500(EventQueue.java:97)_
_ at java.awt.EventQueue$3.run(EventQueue.java:709)_
_ at java.awt.EventQueue$3.run(EventQueue.java:703)_
_ at java.security.AccessController.doPrivileged(Native Method)_
_ at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:76)_
_ at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:86)_
_ at java.awt.EventQueue$4.run(EventQueue.java:731)_
_ at java.awt.EventQueue$4.run(EventQueue.java:729)_
_ at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)_
_ at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)_
_ at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)_
_ at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)_
_ at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)_
_ at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)_
_ at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)_
When I click on "Connect" afterward I have this message
USB device found
not accesseable : busy?
USB device found
Thank you for your help, I've had a great time with my axoloti so far
