When I first saw Axoloti, I got excited (as I still am) about the potential, and quickly this formed into an idea for a project which I now call "AxoCube"
Its a combination of hardware and software, that I thought Id document along the way... its goals, progress and general thoughts. perhaps the community can share some ideas and thoughts.
The basic concept is a stand-alone virtual modular that can be controlled by expressive controllers that are normally tethered to a computer...
You can see some of my early noodling with the Soundplane and Eigenharp and Axoloti here, I love these instruments for their expression, but don't what to be tied to a computer.
The Push, is a fantastic controller, with plenty of controls but also pretty uniquely a great display, I want to use this to control Axoloti in a similar way to the way used in Ableton... my initial attempts can be seen here
Current setup is:
- 4 x Axoloti cores
- Raspberry PI2
- Capacitive touch LCD screen
- 7 port MTT powered USB hub.
The main 'engines' are of course the Axoloti (plural?) , these will be used for voices, fx and sequencing and also controller integration. the PI2 is currently being used for Eigenharp/Soundplane control, possibly later wireless OSC support. the LCD will be useful for general status and perhaps patch switching type features. (the exact divide between this and the push is 'work in progress') . The USB hub, means there is only small power input (5v 2a), and provides either host control via Mac, or from the PI2.
Note: this is far from the final configuration, consider a development setup... the PI2 in particular is likely to be replaced/removed. more on that later!
