Hey guys,
I've been chewing on the idea of an Ax version of the Ciat Lonbarde Cocoquantus. In essence, it is a dual-delay with multiple points of modulation. In practice, you can record and then instantly play 2 separate loops, and them mangle the bejesus out of them. I'm trying to work out how this would work within the Ax though, which is difficult.
Essentially, what I would like to do is:
Hit a toggle to start recording, then when I release the button it plays back (like @SirSickSik 's  Flooper, for example)
Then, as the loop is playing, be able to route some LFOs/ADSRs to various parameters, such as: loop speed, position, direction, pitch, etc. Is there an object that would do this that I'm missing? Or can the Flooper be modified so that various parameters can be controlled by Blue outlets/inlets?
