After perusing the various eurorack related threads it seems to me that the flexibility of what the Axoloti can do makes it hard to pin it down to a single ideal realisation as a Eurorack module. I quite liked the Euxoloti idea but as I read further into it felt it was a bit too complex.
I wonder if the expandable capability of the Music Thing Turing Machine, or the Expert Sleepers Disting might be a model for a good way to integrate the Axoloti into Eurorack.
Essentially the core module would be simply integrated in its power supply, the board would be split into two and the existing boards exposed to the world in a 'Core' Eurorack module that is not fully 'eurorack' integrated but just conveniently mounted and powered. It would however carry a header PCB that exposed its pinouts as expansion headers. The 'Core' could take on different personalities simply by booting up different patches from the SD card.
Note that because Axoloti supports some of the Mutable Instruments algos, it could then effectively be sold as a way of getting a few of those into Eurorack which would in itself be a market.
Then a wider variety of DIY expansion modules could provide I/O and other UX. So suppose you could have two expansion headers one for UX and one for I/O. Each of those would only need a small PCB for the interfacing hardware eg: for voltage conversion. So they as whole would make very easy to build DIY kits. I've sketched these as AXO-IO and AXO-UI
For many musicians, even the UX needed to create patches on Axoloti could be a bit challenging, so for them, precreated patches on the SD card could make the Axoloti available as a meta module capable like the Disting of changing its nature depending on what patch is loaded from the SD card.
A small UI on the front of the Axoloti Core module could then be used along with a simple cursor button to loop through the list of patches on the SD card.
I think a big benefit of this concept could be of creating a module market for the board, and might then provide the economic impetus to expand and develop the concept further.
