HI!
I'm doing an interactive installation and I want to switch on and off a laser using the gpio pins. I got some 3v relays and connected them to the axoloti but seems that the gpio pins can't provide enough "juice" to activate the coil of the relay. (~100 mA). I tested with my reg powr supply and the relay works perfect even with 2 volts from it.
But axoloti will not do it even sending the maximum value to the gpio pins (3.3v checked with voltmeter).
Also tried powering the Axo from a 1 amp 5v supply and no luck..
Any advice? trick? Alternative?
I know I maybe should be using a FET but I don't know which one..
